I tried TMPG, SVCD2DVD and LIGOS. I get mouse-teeth with the first two encoders.
Only LIGOS works, however the encoding sux (out-dated encoder).
Being this is a 4:3 ratio that I have and also that this is a CG movie, is there
any special setting I need to consider?
I have the movie divided into 7 .avi files which play perfectly.
What are you trying to create ?
If it is a DVD, use your original, rip it with ripit4me, and reduce it's size with DVD Rebuilder or burn to a DL isc.
If you want to get a smaller version, rip your original with RipIt4Me, then use a better conversion tool to get the output you need. AutoGK is great for single CD or double CD size AVIs for travel.
If you have aquired the avi files elsewhere or don't own the original then I can't offer you any other assistance.Read my blog here.
What mice use to eat with?Originally Posted by olyteddy
Seriously, I think he means interlacing artifacts. -
Looks like one of the many issues caused by DVD to avi to DVD conversion.
Google is your Friend
Did I use the best settings for a blu-ray rip (The Incredibles)
By AndyD in forum Blu-ray RippingReplies: 3Last Post: 1st Sep 2011, 08:19 -
Teeth (not Mice!).
By Compo in forum DVD RippingReplies: 16Last Post: 18th Aug 2011, 14:03 -
Trying to back up...
By biged670 in forum Newbie / General discussionsReplies: 2Last Post: 1st Jul 2009, 09:54 -
Take a look back.
By gooberguy in forum Off topicReplies: 7Last Post: 21st Jul 2008, 13:22 -
DVDs on hard drive for back up and play back on TV
By yadoc in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 21:03
