So I have the above and most of the time playing back divx/xvid files works perfectly fine.
Till recently when I tried a certain xvid file where the video kept pausing every few seconds (though the audio continued fine). Rencoding it at a lower bitrate enabled it to play so I assume its only a bitrate issue and not something else.
What I'm wondering is if there is a way to find out the max bitrate my player can handle. It doesn't mention it in the manual. Anyone know?
Do you still have the original avi file ?
it would be interesting to compare g-spot 2.60 screenshots of the before and after avis. There are other factors, such as GMC and QPEL that can cause playback problems. It may be that you changed these when you re-encoded, and that bitrate wasn't the issue at all.Read my blog here.
Xvid and Divx playback problem on TV set
By herbapou in forum Media Center PC / MediaCentersReplies: 3Last Post: 7th Sep 2008, 13:17 -
Pioneer dv-400v XVID playback problems
By ironzenmountain in forum DVD & Blu-ray PlayersReplies: 15Last Post: 4th Sep 2008, 00:22 -
Lite-On 5045GDL+ and bug with DivX & XviD playback?
By NorseGuy in forum DVD & Blu-ray RecordersReplies: 0Last Post: 2nd Apr 2008, 11:51 -
MPEG-4 Playback Means DivX/XviD, Right?
By p_l in forum DVD & Blu-ray PlayersReplies: 1Last Post: 21st Dec 2007, 22:32 -
whats the best dvd player for divx/xvid playback?
By saxon in forum DVD & Blu-ray PlayersReplies: 19Last Post: 19th Jul 2007, 12:55
