    Jan 2003
    I have been using my burning with DVD+Rs ever since i got it and they worked every time. My friend accidently bought me DVD-R so I decided to try it and see if they would work and they did. So i went back to my DVD+Rs and now everytime I try to burn a movie they give me an error at the end of the process. Why is it doing this?
    Stoked
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    What type/brand of disks are you using?
    Jan 2003
    Memorex. Ive always used them in the DVD+R format but i just tried memorex in the DVD-R format because a friend bought them for me, and now my DVD+Rs aren't finalizing.
    Stoked
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    What software are you using? What is the exact error? Have you verified all of the software settings? Some settings change by disc type.
    Google is your Friend
    Jan 2003
    I am using the Nero 7. The error I get says cannot Finalize or Lead-out. I have never changed any software settings.
    Stoked
