I am considering adding an internal notebook DVD writer to my notebook computer. Does anyone have any info on the good versus bad notebook DVD burners? There is a lot of info on standard burners but I haven't heard any reports on internal laptop burners.
That's because there are no such thing as "universal" internal notebook burners. You have to take whatever the manufacturer give you.
I am aware of the difference in packaging. The various manufacturers use adapters that hold the drives so they fit the laptop case. My question has to do with burner performance info - you know like "Pioneer good, Sony bad". I can handle the packaging issues.
The replacement DVD burner I bought for my HP laptop was about $190US. I'm not aware of any other burner that will fit in or connect to my laptop, at least. Some now use a 'cartridge' system where you can just pull it out of a slot, but I spent about 3 hours taking mine apart and putting it back together to replace it.
But if you have a choice, I would go for a Pioneer over a Sony burner. And I haven't seen much of anything about specifications for laptop internal burners. You might check with CD Freaks as they seem to have quite a bit of DVD burner info: http://www.cdfreaks.com/ -
SCDVD,
I have a Dell Laptop with a NEC ND 6650A Dual layer burner in it and so far I've had no issues with it, I do more MPEG-4 Video than DVD but it has probably burned 25 DVD's so far with no coasters. I have done a couple of CD projects that required multiple burns and for that I have a BenQ burner (1640?) in a cheap USB/FireWire enclosure that I use externally via the USB 2 Ports, These notebook drives seem pretty fragile and produce a lot of heat, so I try and limit my notebook burner to single discs, I think I have a little less than $100.00 CDN in the External DVD Burner and it also does faster burns. Something to think about.
How do you connect an internal Blu-ray drive to a laptop?
By rayden54 in forum DVD & Blu-ray WritersReplies: 2Last Post: 13th Jan 2012, 12:31 -
How to Record using 3 External Burners plus 2 Internal Burners with Speed
By mn072065 in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th May 2011, 19:27 -
Are laptop CD burners limited to 24X?
By sdsumike619 in forum ComputerReplies: 4Last Post: 21st Feb 2009, 00:10 -
Which of the FOUR internal DVD burners is best ?
By MacPCConsultants in forum DVD & Blu-ray WritersReplies: 40Last Post: 29th Nov 2007, 22:56 -
Do internal/external DVD burners have copy protection built in?
By waldothewonderboy in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jul 2007, 00:01
