  1. I can not find the remote controller codes to Pioneer DVR-530H-s. I seek such which 0.6.5 are compatible with WinLirc (WinLirc open only *.cf files). I will add only that I do not possess the original remote controller (totaly destructed) so now learning WinLirc is not possible. Mayby anyone has this codes.
    Someone has some idea?
    Greetings - Jacek
    Sep 2006
    I purchased a OneForAll remote URC6131n, didn't work but customer support said i could send it in and have it upgraded for free (except for shipping) or suggested that i buy model URC-8910 which is upgradable by phione. If your AllForOne remote is compatible it will use remote code# 0631, they added.
    I downloaded a .CCF (Pronto file) form remote central to install into a Palm, but requires a PDB converter which i have not tried yet : search for ccfcnvt.zip (converts CCF for palm use)
    The 530HS does not have the TVGuide system, but i do know that the Timer Record buttons on the remotes described below will activate both TVG and VCR+ menus.
    I ended up buying a new remote from pioneer because i bought an open box Pioneer 531 without remote. Pioneer model number VXX2967 (ended up being like $50 U.S. after shipping) http://parts.pioneerelectronics.com/part.asp?productNum=VXX2967 which works with all Pioneer DVR with hardrive, as far as I know.
    Before that, I used the remote from my DVR-220 (VXX2928) until I got my new one. It is just missing the HDD and DVD buttons, so had to push those buttons manually.
  3. Thanks for support in this task.I order remote controller yesterday from Pionner (160 PLN - about 53$ with shipping)
