    Oct 2003
    India
    OK. Here i'm gonna post a few dvd-playing problems ive been facing now:
    I bought a DVD with 4 titles, and since i1 of them wasn't working i wiped the dvd with cotton and aftershave(it has workd 4 me many times) , bt the dvd stopped working altogether now. Its got faint abrasions all over its surface.
    I hav another perfectly clean and scratch-free dvd. Wen I put it in the DVD-RW(Sony DRU-810A) drive, it just tries 2 read 4 sometime, then stops. Why?
    And dis ones the wierdest. In another dvd, wen i put it in the DVD-RW drive, it keeps on scanning the DVD, and in My Computer, the "DVD-RW Drive" changes to "CD-ROM". But the DVD plays fine on myy Sony mini home theatre (MHC-DP900D), which usually is very picky abt DVDs and didn't at all play the previous 2 DVDs i mentioned. btw, dis DVD has only a few minor scratches(not a problem at all)
    And yeah, the lenses of both the DVD-RW and DVD player were cleaned.
    Thanx
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    I'd have taken it back for a refund... Sounds like your aftershave wasn't all that good for the DVD surface.
    /Mats
  3. Member steveryan's Avatar
    Jan 2003
    Manchester
    What aftershave was it? I'd recommend using Hai Karate for all your DVD cleaning needs.
    He's a liar and a murderer, and I say that with all due respect.
  4. Mod Neophyte redwudz's Avatar
    USA
    It sounds like your DVD-RW drive has problems. How did you clean the lens?
    BTW, you might want to check your Control Panel>System>Hardware>Device Manager>IDE ATA/ATAPI controllers and see if that drive is still in DMA mode. Windows XP will turn off DMA mode for a device after encountering certain errors during data transfer operations. If more that six DMA transfer timeouts occur, Windows will turn off DMA and use only PIO mode on that device.
    Oct 2003
    India
    The aftershave i used was Axe Denim. And i checked; the DVD-RW is still in DMA mode.
    It wont b possible 4 me 2 get a refund coz i got it from a brick and mortar shop wile i ws away on vacation. (The trip's gonna cost me more than the DVD). I used a CD lens cleaner from Frontech ( a Taiwanese brand if u havent heard) 4 cleaning the DVD-RW.
    U sure my DVD-RW is the problem? Seems all my DVD drives r going kaput. My LG DVD ROM died a while ago. Do DVD drives go bad if u use them less 4 reading DVDs and more 4 CDs?
    Oct 2003
    India
    c'mon guy. pls help me here...
