Well I opened a .ts HD video file with power dvd and it says that you should turn CLEV-2 and smart interlace off and so i did. Movie looks fine. But it appears that it set it as default for almost everything. I was watching a 1080i quicktime trailer with quicktime player. and minimized or another other size looks fine but if I put any video full screen including some .avi the colors are very dark. But if i launch another .ts with power dvd and then put use these fuctions and then pause it and then goto the quicktime movie then the fullscreen is fine but once powerdvd is closed it sets those options off again. So how would I go about leaving the CLEV-2 ON for as default for my entire computer?
Results 1 to 1 of 1
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
Can't enable CLEV-2 with PowerDVD 7 ultra/aspect ratio incorrect
By timbop37 in forum Software PlayingReplies: 0Last Post: 15th Jan 2008, 05:56 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
