Hi again,
I have an AVI which contains AC3 audio. My goal is to extract the AC3 from the AVI and use BeSweet (?), AC3Machine (?) - (you tell me) to end up with the 6 mono wav channels.
Is this even possible?
Thanks,
Justin
Results 1 to 11 of 11
Load the avi into virtualdubmod. Click on Streams->Strea List. Highlight the audio track and click on Demux. Save the ac3 file to a new location.
I don't use besweet, so you will have to work out the next step on your own.Read my blog here.
Huh (in a pleased way),
You did it again. Much appreciated
Thanks,
Justin -
Interesting (to me anyway),
These AVIs that are supposedly 5.1 are apparently 5.0. Has anyone else noticed this? ... assuming anyone else has checked out the 6 AC3 channels in an AVI :P -
A lot of commercial discs are mastered with little or nothing in the LFE. If you don't have a decoding amp and you are getting the downmixed stereo then you don't miss it because the LFE isn't included inthe downmix. If you do have a decoding amp, most have a threshhold set low enough that the LFE stays busy even without a dedicated channel in the mix.
Read my blog here.
Hi-
Although there is such a thing as DD 5.0, most really are DD 5.1. If you play the DVD in PowerDVD and turn on the OSD, it'll tell you what kind of audio it has. If you open the AC3 in HeadAC3he, it'll tell you. I think GSpot will as well, by opening either the AVI or the AC3 track. As guns1inger says, there often just isn't much going on in the LFEs.
If you're decoding to 6 Mono WAV files, and then playing the LFE, you can often go long stretches before hearing anything. You can open it in a WAV editor, find where the waveform is actually doing something, play it at that part, and hear it. -
Hm,
Well I looked at the waveform in Audition and it's completely flat. Though, I guess I could've boosted it to see if there's anything there. I just figure that if there's no trace of anything without boosting it, it's most likely entirely empty *shrug*
- Justin -
I'm just curious, what is the point of doing 6ch mono
moved to another forum, nobody likes me here... -
I'm not sure what you're asking. What do you mean by "the point of doing"?
If you have 6 channels audio in mono signal you can't enjoy sourround sound, which is what is the purpose of haveing 6 channels audio.
AC3 to AAC Troubles - Need Help
By stilllogicz in forum AudioReplies: 30Last Post: 10th Aug 2012, 05:42 -
Converting AC3 to MP3 on AVI
By hilario in forum Video ConversionReplies: 22Last Post: 18th Jun 2011, 01:37 -
UGH!!!! READ problems again, this time with Sony DVD burner Sata 22x
By Clint Eastwood in forum DVD & Blu-ray WritersReplies: 5Last Post: 15th Feb 2009, 01:31 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
converting mpeg2/ac3 and avi/ac3 to avi/lambmp3
By corumz in forum Video ConversionReplies: 2Last Post: 17th Sep 2007, 09:32
