I'm using a matrox rtx.100 card to capture video from vcr sony slv ez745.
I'm able to capture video and encode to dvd using PPro 1.5 , but the end result as seen in the dvd, the picture is out of alignment as originally captured.
My problem is that the captured video from the vcr to the card is aligned downward as seen in PPro 1.5 capture window. There is a blank strip on top of the video, and about one inch of the bottom part of the video is missing.
Is there a setting I need to adjust? I have another vcr of the same model, which I tried using and I get the same result.
Any suggestions?
It sounds like the aspect ratio is adjusted wrong. The program may be converting a 4:3 video to 16:9 which would give you a blank area top and bottom. I'm not that familar with the program, but someone here likely has the cure. Just stand by.
And welcome to our forums.
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 01:54 -
I'm transferring about 100 VHS tapes - pixellation problems
By mw01908 in forum Capturing and VCRReplies: 32Last Post: 15th Sep 2011, 02:05 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 09:19 -
Is Canopus 50/55/100/110 REALLY god's gift to the VHS-capture universe?
By miamicanes in forum Capturing and VCRReplies: 40Last Post: 27th Nov 2007, 15:17 -
Advice: Capture via Matrox RT.X2, EDIUS NX Express, or Composite on DV cam?
By Riker0007 in forum Capturing and VCRReplies: 1Last Post: 11th Jul 2007, 16:30
