ok. i am trying to use my TV as a monitor. my TV has a female 4-pin s-video port. my videocard has a RCI port. an RCI cable is going from my PC to an RCI/S-video adapter, and from this an S-video cable is going to my TV. i can see the picture on the TV but it's like black and white and all jumpy. i tried changing the channel on the TV but that's apparently not the problem. any ideas???
	Did you mean: RCA to S-video adapter ?Originally Posted by djtizzy
 Yes that would look terrible because they are only supposed to work in reverse.
 Just go composite (RCA) from display card to TV composite (RCA). Or S-Video on graphics card to TV composite (RCA). Or S-Video on graphics card to TV S-Video.
	yeah i meant RCA.Originally Posted by edDV
 my graphics card does not have an s-video port. it only has an RCA and of course the standard monitor port.
 my tv does not have RCA. it only has s-video.
 that's why i have the RCA/s-video adapter.
 do i need to get a new graphics card to make this work?
	It sounds like your videocard is outputting PAL,remove your videocard and make sure the switch is set to NTSC.Also set your PC screen to 800x600/60Hz/16bit.
 If that doesn't help then buy a videocard with S-Video out.
	To make RCA to S-Video work, you need a Y/C separator (decoder) in the path. A new video card is cheaper and a better solution.Originally Posted by djtizzy
 http://www.newegg.com/Product/Product.asp?Item=N82E16814127128
 http://www.newegg.com/Product/ProductList.asp?Order=PRICE&Page=1&Category=38&N=2010380...SubCategory=48
 The technical reason for the bad picture is you are dumping luminance into the chroma path and filling it with false color.
 You can read about Y/C separation here. S-Video has Y and C already separate.
 http://members.aol.com/ajaynejr/vidcomb.htm
  .mov playback in video editors sucksBy RoundPorch in forum Newbie / General discussionsReplies: 6Last Post: 19th Oct 2011, 17:11
  Understanding video adapter resolutionsBy GordonVCD in forum ComputerReplies: 7Last Post: 15th Jan 2011, 21:39
  S-Video to HDMI cable/adapterBy JohnnyBob in forum Newbie / General discussionsReplies: 16Last Post: 22nd Nov 2010, 13:42
  Video adapter information unavailableBy Grnd91 in forum RestorationReplies: 1Last Post: 31st Aug 2010, 07:27
  USB to DVI Video Adapter?By lenny_67 in forum Media Center PC / MediaCentersReplies: 0Last Post: 19th Mar 2010, 12:24
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
