Page 2 of 2
FirstFirst 1 2
Results 31 to 38 of 38
  1. manono,
    The problems are related.... the same even.....so it might involve less going around in circles to continue the discussion in a single thread. If you care to join us over here.... https://forum.videohelp.com/threads/358043-A-comparison-of-AVIsynth-denoise-filters?p=2...=1#post2463389
    I've never used BDRB but if the scripts I've seen posted over the years are any indication it often uses DirectShowSource and I think that's the "perspective" Lathe is working from.
  2. Member Lathe's Avatar
    Nov 2007
    Sunny Southern California
    manono,
    Oh, okay, sorry... I'll go over there.
  3. Originally Posted by Lathe View Post
    So, the only way around that is to create a BDMV folder which my OPPO will play
    Your Oppo also plays DVDs. You can keep it at 720x480 and encode for 16:9 and 23.976fps with soft pulldown applied.
    Thus the need to add borders. I KNOW that the AR is not quite right
    That's putting it mildly. Besides which, none of the resolutions (from the script or mentioned in your post) are remotely Blu-Ray compliant.
    Normally I would go with a perfect 16x9 ratio (in this case it would be 864x486) BUT... with this particular print, it looks too wide so I'm adding the extra padding on the sides.
    There's some funny business going on, no doubt. Crack In The Mirror is supposed to be 2.35:1 so whoever made the video already took some really big liberties with the aspect ratio.
    Maybe then you can help me look into the greyscale thing if that is okay?
    Greyscale()
    or:
    Tweak(Sat=0,Coring=False)
  4. Member Lathe's Avatar
    Nov 2007
    Greyscale()
    or:
    Thanks Bro! I will read up on the 'soft pulldown' thing so I can understand it. I'm guessing that you MIGHT mean to run the inverse telecine script to make it progressive, right? Thanks too for the greyscale thing (interesting how tweak does that too with that setting)
    I will definitely read up on both of these.
    Appreciate it!
  5. Originally Posted by Lathe View Post
    It just means for you to add 3:2 pulldown. Some do it through the encoder. Others (me included) do it after the encode using DGPulldown.
    No, I was assuming you made it progressive 23.976fps in the script and encoded it as such in your MPEG-2 encoder. Followed by applying 3:2 pulldown so it outputs interlaced 29.97fps as required for NTSC DVD.
  6. Member Lathe's Avatar
    Nov 2007
    Hmmm..., well this just goes to show that I have some SERIOUS reading to do!
    BTW, just to see what it looks like, I ran the now progressive file with the Greyscale() script, and it took out all those funky color patches that were in it! So whatever I do next, I will for SURE include that in the script.
    Just a quickie, if I may... When using the Greyscale() script, does it do ANYTHING else to the image? Does it soften it / sharpen it, or have any other byproducts, or does it just take the colour out?
  7. It just takes out the color. Since both Greyscale and Tweak are built into AviSynth, you might consult the Greyscale and Tweak pages on the AviSynth site.
  8. Member Lathe's Avatar
    Nov 2007
    I will check those out, thank you!
