Hi everyone,
I have an image of a DVD, format is .iso. I mounted it with Daemon-Tools and "Copy DVD" using Nero Burning Rom. When I played it on my DVD player, there were skippings like every minute. Does anyone know what's the problem?
Is there a better program to burn .iso to dvd, rather than Nero Burning Rom? I heard Ahcohol 120% can burn "perfect" copies. Has anyone try it or recommend it?
The freeware ImgBurn should work better than Nero for that. Does it play properly before burning? Even Nero should burn a ISO directly without using Daemon tools.
With Nero, just select 'Burn Image' under the 'Recorder' heading and select the the ISO file.
Are you sure your problem isn't your media? That is by far the most common problem with a burned DVD file. -
if u can play the .iso just fine, and u turned on Nero's verify, then the prob is your player doesn't like that particular media.
You are correct, jsmithepa. It was my dvd player's problem.
Thank you guys. I didn't know that I can burn the iso directly using Nero's Burn Image.
Can you mount an .ISO image to a hard drive , then copy the VIDEO_TS folder
By Bansaw in forum Newbie / General discussionsReplies: 8Last Post: 19th Jul 2011, 19:11 -
Ripped A DVD With DVDFab But ISO/Copy Plays Horribly. Please Help.
By Blacker in forum DVD RippingReplies: 8Last Post: 3rd May 2011, 19:49 -
Perfect copy until last chapter
By Vincent44 in forum Authoring (DVD)Replies: 10Last Post: 11th Sep 2010, 12:52 -
Perfect DVD copy with all the menu's but half the file size
By Kozanator in forum Newbie / General discussionsReplies: 12Last Post: 5th Mar 2009, 10:44 -
Can't copy a (ISO) DVD I just burned in Nero
By perceptionist in forum Newbie / General discussionsReplies: 5Last Post: 5th Jun 2007, 22:49
