I'm spec'ing out a Dell XPS 410, and I'd like to hear some opinions from the peanut gallery.
Asid from the cpu (still haven't decided on the model # of Core2Duo, but it will be a Core2Duo), and the video-ready only (I recently bought an Ultrasharp 1907FP for my current pc), I'm not sure whether to go with:
ATI 1300 Pro OR GeForce 7300 LE Turbocache (both are 256mb). I don't really do any pc gaming, but I do want good performance when editing.
The smallest hd offered is a 250gb SATA 3 drive. I figure I'll choose this drive to save some money, then buy a smallish, fast drive (40gb raptor?) for my OS drive, and shift the 250gigger to D: as my media drive.
Single CD/DVD burner. I have a Sony 16x burner in my current pc that i'll move over.
Any thoughts?
BTW, the price for my current config is $875. Not bad for a core2duo rig, eh? I was thinking about building my next pc, but the whole cpu/heatsink/thermal paste thing scares the heck out of me (I was never very good with model airplane glue either).
Thanks!
Gary
A few thoughts: In general, your video card should have no effect whatsoever on editing. It's for watching. If it's a capture video card, then it becomes important for that use.
Good move with the hard drive. Keeping video off your boot drive is a good idea. But a Raptor is probably a waste of money. The OS doesn't go that fast.
And your controller may not either. An 80G SATA is plenty.
Most factory CPU coolers come with a thermal pad, so you don't have to mess with the 'gunk in a tube'.
If they offer a factory cooler with the CPU, it usually gives a longer warranty. Sometimes a very good deal.
If you use a program like Shrink, a second DVD drive may be a good option. Burners are not much more than ROMS these days, so a second burner for reading, and one for writing, may speed things up. -
Thanks for the reply!
Re: the single DVD burner, I meant that I'll order the Dell with a single dvd burner, then move my Sony burner over alongside it.
Here's another question(s)...Given the properietary nature of the Dell case, system design and certain components, what can I expect from the XPS 410 psu? I'm not familiar with the various psu specs out there, but I have this incredibly annoying slow, multiple spin-up problem with the optical drives on my current Dimension 4500, and I could swear it's just a matter of the crappy psu not being able to power it up quickly. Is the XPS 410 psu a good one, and if not, is it easily replaced with a betterbrand/model? I know the 410 uses the BTX case design, so maybe they skimp on the psu to keep the noise down?
Thanks!
Gary
Dell XPS 420 memory problem
By Prot in forum ComputerReplies: 11Last Post: 20th Apr 2011, 12:14 -
MKV2AVI best configuration
By katalogas in forum Video ConversionReplies: 0Last Post: 15th Jun 2010, 06:38 -
anyone with a Pioneer DV-400,410,420 player have his problem?
By spiritgumm in forum DVD & Blu-ray PlayersReplies: 0Last Post: 1st Nov 2009, 11:03 -
Pioneer DV-410
By geroglifico in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th May 2009, 05:08 -
help for code zenith xbv 410
By amboss in forum DVD & Blu-ray PlayersReplies: 1Last Post: 7th Jan 2009, 13:49
