I have a avi file that is about an hour long. I just want a scene from the file that is about 5 minutes long. I re-encode the original avi file using xvid and a mp3 codec. My problem is that I can't get Tmpgenc to encode the audio in VBR. Tmpgenc only encodes it in CBR. Any ideas how to get VBR audio to work? I have Xvid and Lame installed.
If you are using TMPGEnc encoder for Xvids, it's really not that good at that proceedure. It was made to be a MPEG encoder. I would use a program that is made for AVI encoding. VirtualDub would be my first choice. If you want a all in one type converter, AutoGK, avi.Net or FairUse Wizard are three popular ones. But they will all use the very same Xvid codec. VD is a little harder to learn, but much more flexible. And it does a lot more than just edit.
And I wouldn't encode any AVI audio in VBR format. It's acceptable for helping to crunch down the size of a Xvid for sending over the net, but useless for much of anything else. It causes lots of sync problems if you need to re-encode the video to a different format later. For the few KB you save on audio file size, you just generate many more problems for everything else. I would stick to MP3 CBR.
VD can easily chop out a small clip from your AVI, and you don't need to re-encode it, if the format it's using is the one you want. You save it out as 'Direct stream copy'. Only takes a few seconds. VD can also use LAME MP3 as a audio codec. -
Thanks. I'll give VD a try. Sounds pretty good. Thanks for all the information. Very helpful.
Edit a movie (avi), cut some scene but KEEP subtitle in synq! HOW TO??
By GiBsom in forum EditingReplies: 5Last Post: 18th Dec 2013, 19:58 -
Retaining HDV scene split on tape?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 6th Oct 2010, 10:18 -
DVD split with DVDFab. Movies don't run smoothly, goes back to first scene
By whenloverageswild in forum DVD RippingReplies: 1Last Post: 15th Jul 2009, 14:16 -
How to convert DVD to AVI and cut out a scene?
By superJT in forum Newbie / General discussionsReplies: 13Last Post: 15th Apr 2008, 15:03 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 01:00
