Page 2 of 2
FirstFirst 1 2
Results 31 to 34 of 34
  1. Video Restorer lordsmurf's Avatar
    Don't fall too in love with tha Hauppauge over a an ATI AIW. The Hauppauge has a noticely softer picture, around a 5-pixel radius or so. It's especially obvious in Half D1 mode. So be sure to factor this in while deciding between the Hauppage and the ATI.
    Don't worry too much about CPU usage. You should not use the computer while capturing anyway, and your super-powered new CPU won't even take a small dent.
    Jul 2004
    LOL I don't know about superpower but Pentium D maybe which are a far cry better than my P4 and probably MUCH cheaper then buying a new core2 duo
  3. The slowest C2D, the E6300, is a little faster at video encoding and a lot cheaper ($180) than a Pentium D 960 ($342):
    http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2795&p=12
    http://www.newegg.com/Product/Product.asp?Item=N82E16819116247
    http://www.newegg.com/Product/Product.asp?Item=N82E16819115005
    Of course, you can get slower Pentium Ds for as little as $90. And relative encoding speeds can vary depending on the encoder.
    Jul 2004
    Hmmmm..Thanks!
