Hi there,
i'm exploring the need to use a dvd recorder for some of my transfers. to date, my transfer have been small enough to software encode and run overnight. now, i am getting folks bringing their entire libraries to me. as you can imagine, i need to...um...save some time as it's a long process
So, one of main issues is to ensure I offer solid quality and to correct the tapes using TBC. I do this currently with a canopus advc-300 which does a fantastic job. i've now read that dvd recorders are now incorporating this feature.
i saw this post which said that recorders were using 'line' tbc which is a lesser type of tbc
https://forum.videohelp.com/viewtopic.php?t=250528&sid=66370ce295d9411a6ab7da42b96bca69
this post was from last year so i wonder if it's still valid? is anyone using a TBC recorder and noticing huge improvements in colour saturation and jitterness (if that is a word? if so, please list the brand.
also, it would be great if i could connect the recorder to my macs via firewire. if i can, can i transfer data from the mac to the recorder for burning?
finally, is anyone using a recorder such as i described for video transfers? any feedback would be hugely appreciated. i tried talking to some electronic stores and they didn't know squat about the process.
cheers,
keebler
No, it is not valid. DVD Recorders have an internal TBC/Frame Synchronizer, also commonly referred to as a "Full Frame TBC".Originally Posted by Jedi27
Toshiba DVD Recorders provide exceptional TBC performance, particularly with respect to horizontal jitter. Comparison tests can be found here;
https://forum.videohelp.com/viewtopic.php?p=1482771#1482771Life is better when you focus on the signals instead of the noise.
DVD Recorder to use as a pass-thru TBC? Need HELP
By ruehl84 in forum Capturing and VCRReplies: 39Last Post: 8th Apr 2025, 07:33 -
Who uses a DVD recorder as a line TBC, and what do you use?
By BrainStorm69 in forum Capturing and VCRReplies: 190Last Post: 5th Jun 2017, 10:26 -
AVT-8710 TBC & Lack of RCA Audio Input/Output - Will It Matter?
By NY2LA in forum RestorationReplies: 45Last Post: 25th Oct 2010, 20:53 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 02:36 -
TBC's, TBC's, TBC's, upto my knees ........ puzzling over sync controls?
By StuR in forum RestorationReplies: 6Last Post: 22nd Nov 2007, 12:58
