I rip subtitle from DVD into *.son file.
but after import it to DVD-Lab Pro, it's arrange my subtitle to center as in this picture.
How can I config DVD-Lab Pro to use position in *.son file instead of put all subtitle entry to center ?
Any suggestion is appreciated.
Regards,
When you import your subtitle file, next to the subtitle line is a little folder icon, and next to the folder icon is the subtitle position indicator. Click on that little underline, select a position and check the "Apply to all Subtitles" option.
Regards,
George -
Originally Posted by GeorgeW
But my subtitle is contain some line that on top right and some line that on center bottom.
Can DVD Lab-Pro arrange it by value that come with *.son file ? Or I have to arrange it manually ?
Regards,
DVD Lab Pro - Import .SSA subtitle problem
By satan999 in forum Authoring (DVD)Replies: 3Last Post: 27th Jan 2011, 07:21 -
DVD Lab Pro - New OS, same location of files = Subtitle generation = crash
By Paker in forum Authoring (DVD)Replies: 5Last Post: 18th Sep 2010, 08:56 -
adjust dvd subtitle position
By pcb in forum SubtitleReplies: 1Last Post: 27th Aug 2008, 18:42 -
DVD Lab Pro Subtitle Mapping issues
By ArtOfLosingMFZB in forum Authoring (DVD)Replies: 1Last Post: 2nd Feb 2008, 20:41 -
Joining M2V & AC3 files for DVD burning, Subtitle creation sub position
By blue2 in forum Authoring (DVD)Replies: 15Last Post: 29th May 2007, 08:56
