I'm trying to make a DVD from an DV .mov file but am having a problem. It seems that on the keyframes/I-frames, the image softens, far more than in all B & P frames. I found this by loading up the MPG file into MPEG Streamclip and navigating via I-frames. It is visible as a pulse in the image every half second when the clip is played back.
This is definitely not an artefact of the original footage, and happens whether I choose FFMPEG or MPEG2ENC to create the mpeg2 files.
Is there something I can do with the quantiser to minimise this or is it something to do with using DV footage? (though trying to encode with iDVD does not introduce this artefact).
Results 1 to 1 of 1
blur two locations of a video Mpeg2-TS
By prisoner in forum EditingReplies: 5Last Post: 26th May 2011, 01:14 -
How do you blur selected frames in AVIsynth?
By Nagashi in forum EditingReplies: 4Last Post: 9th Jan 2011, 19:30 -
H264: tool for swapping frames without re-encoding?
By fvisagie in forum Video ConversionReplies: 9Last Post: 23rd Feb 2010, 20:52 -
how to create avi from mpeg2 with only I-frames?
By ecc in forum SubtitleReplies: 3Last Post: 20th Feb 2008, 07:14 -
MKV to MPEG2 - Not dropping frames, but not smooth - think it's audio
By Shade00 in forum Video ConversionReplies: 11Last Post: 18th Feb 2008, 13:20
