i have an old music mpg and i want to strip the audio from it to increase the volume...the volume is very low....i know virtualDub does this but can i reconnect the audio track to it w/o having to reencode to an avi then back down to an mpg? Or if I reconnect the audio track...will it increase the size of the mpg substantially?
moontrash
Results 1 to 9 of 9
you determine the size of the audio by what bitrate you choose to encode it at. higher volume isn't going to mean a bigger file size, but higher bitrate is.
you should be able to demux the audio/video, edit the audio and re-encode it to the same bitrate as before, then mux it back together again with no encoding of the video. -
i got an error saying cannot open file..using virtualDub
moontrash -
Vdub will not open mpeg files. VDub-Mpeg2 will open the file. You will not be able to remux them back together with VDub-Mpeg2 though, it can only save as avi files.
TMPGEnc, the free version, has an mpeg demux/remux function that will work. File-->Mpeg Tools.
Once you have demuxed the files, you can do whatever you like to the audio and then remux them together.Melde Melda Vessė
Eruanna ar Eruntano Melda Eruntanohini
"May your days be bright and contact with stupid people limited." -
well...tmpg tools did the de multiplexing but theres an issue now...the video/audio is 2:36 long...the audio when stripped is 1:42 long....this is strange,...the audio is mp2 also...any ideas?
moontrash -
Melde Melda Vessė
Encore increasing timeline size
By koberulz in forum Authoring (DVD)Replies: 47Last Post: 9th Nov 2011, 12:19 -
convert compressed avi files to mpeg without increase in file size?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 7Last Post: 2nd Nov 2011, 06:29 -
How do I strip an MPG 2 of language streams W/O reencoding
By Onceler2 in forum Video ConversionReplies: 17Last Post: 22nd Oct 2011, 07:16 -
Mpg : Mpeg video size and bitrate calculation
By Bonie81 in forum ProgrammingReplies: 2Last Post: 21st Jun 2011, 23:38 -
Standard quality/size for MPEG (*.mpg) videos?
By Ashman01 in forum Video ConversionReplies: 3Last Post: 22nd Feb 2009, 19:55
