Is there a way to use a regular pc monitor as a TV screen? I am not talking about using a Tuner card on the pc to view the TV on the pc. I would like to connect the pc monitor to the cable box/receiver or to something in between. So what options do I have here?
Plenty. There are several in this list: http://www.newegg.com/Product/ProductList.asp?DEPA=0&type=&Description=tv+box&Submit=ENE&N=0&Ntk=all
The Monitor wants progressive VSEA RGB resolutions and frame rates.
The HD cable box puts out composite, S-Video, YPbPr analog and DVI or HDMI feeding 720x480i, 720x480p, 1280x720p or 1920x1080i.
The most likely to work is 480p over DVI. Aspect ratio will be all screwy but you might get it back with H/V size and position controls on the monitor. 720p over DVI may work.
Otherwise you need a box in between to convert analog and interlaced digital sources to progressive VESA RGB resolutions.
That is basically what the computer tuner/display graphics cards and the boxes listed above do.
Options for playing RCA video on my computer monitor?
By will7370 in forum Newbie / General discussionsReplies: 1Last Post: 8th Mar 2012, 22:55 -
HELP: advice external video monitor options for color correcting
By DvdRookie in forum EditingReplies: 3Last Post: 14th Mar 2011, 16:20 -
Turn lcd monitor into a tv Any other options
By canadateck in forum DVB / IPTVReplies: 4Last Post: 6th Nov 2009, 20:28 -
Can I use a headrest monitor as my server monitor when traveling
By regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 08:43 -
what are my options
By bmw2007 in forum Video ConversionReplies: 2Last Post: 26th May 2007, 08:54
