    May 2001
    Brazil
    Hi there.
    I purchased SVCD2DVD a few days ago and I'm very satisfied with it indeed! Great product, does in a couple of clicks what used to take me hours and a plethora of programs to do.
    I have a feeling (just a feeling really), that I used to get slightly better mpg2 compression from CCE-SP, but hey, I'm not complaining.
    What I WOULD like to talk about, however, is this:
    I have this old notebook that I've set aside pretty much just for using SVCD2DVD. I turn it on and it runs for hours.
    But it never lets the notebook's screen go into power-save mode (screen off). I have the windows screen saver turned off so as not to consume cpu cycles with it, but I would very much like the screen to turn off after 5 minutes.... I guess SVCD2DVD does something using keyboard routines, so the O.S. always thinks someone is at the keyboard....
    Best regards,
    Eduardo Baldino
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Not that i can think of. Maybe because the CPU & Hard drive are being maxed out it won't do it...
  3. Just to add to Chrissyboy's reply- my monitor enters power save mode just fine with S2D running.
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
