I pulled MAC3Dec from the tools section but it creates a 2gb AIFF file from just a 15mb AC3 and doesn't playback anything in quicktime. I'm using OSX.
Any recommended freeware converter from AC3 to AIFF?
Results 1 to 15 of 15
Well, from an editing standpoint, its fairly crucial. I'm guessing thats not what albloom's wanting it for, but I work with AIFF all the time and am constantly converting MP3's to uncompressed.Originally Posted by albloom
On that note, albloom, iTunes does a nice MP3 to AIFF conversion (although it won't handle AC3). You could convert to MP3 using MAC3Dec, and then use that file to convert to AIFF with iTunes. The resulting file won't be small, but it shouldn't be 2 Gigs. -
Crucial for editing? Not for Amadeus, which reads and
writes a variety of formats. Besides, as a close personal
friend of albloom, 'twas not he who asked the question.Al Bloom -
You can use MPEG Streamclip to do the conversion. Open the ac3 file and select demux to AIFF. If you have a 5.1 file use the audio mode to select which tracks to convert.
Whoops, misread the posting names. My bad.Originally Posted by albloom
Specifically, I edit content for broadcast on television. I work almost exclusively with uncompressed (at least for my final edit). So, for what I do, I require the highest possible fidelity. Any compression can lead to unwanted side effects when your program goes out over the air. For me, aiff is crucial.
Hi,
If you use SimpleMovieX, you can not only convert to AIFF, but also do some basic editing and resyncronize with video signal.
SimpleMovieX v3.0 now displays audio as a waveform like in iMovie.
Note that I'm the developer of this little app.
http://www.aeroquartet.com/SimpleMovieX/
For AC3 to work, you must install free codec A52Codec 1.7.2 and your AC3 files must have an AC3 extension (AC3 in upper case characters. ac3 will not work)
Regards, BJ -
Hope this provides more information but I am using the audio tracks in DVD Studio Pro.
Basically, I am pulling files from Final Cut Pro and sound files are in AIFF. Should I just simplify and export the audio tracks to MP3? Does this help cut down file sizes but still retain quailty? -
I seem to be having bad luck with most of these utilities. I am using OSX 10.2.8 if this helps.
I'm taking a 4mb AC3 file and running it through mAC3dec and it is creating a huge 2gb MP3 file that does not playback.
Do I need any other extensions....er plugins?
I just need to get a format that is able to import into DVD Studio Pro. -
DVD Studio Pro can't import an AC3 file ?
Read my blog here.
Getting error codes now with mAC3dec:
mAC3dec encountered the following error:
Could not open data fork of new output file
Err# -49 -
Says file type not supported.Originally Posted by guns1inger
Yes, DVD Studio Pro handles AC3 files with no problems. There must be something odd with your AC3 file in some way.
Need something to convert 5.1 AC3 to 5.1 AIFF on Windows!
By arminio in forum AudioReplies: 4Last Post: 23rd Nov 2011, 14:54 -
recommended bitrate for squeezing out quality of DVD when converting to mkv
By arconreef in forum Video ConversionReplies: 2Last Post: 24th Dec 2010, 16:39 -
AIFF to AC3
By danielmak in forum MacReplies: 9Last Post: 13th Feb 2010, 23:31 -
Converting .flac to .aiff - retaining file name
By macbuz in forum AudioReplies: 1Last Post: 21st Nov 2009, 21:02 -
AC3 -> AIFF, and AOB -> AIFF for Jaguar 10.5.6?
By DeadSirius in forum MacReplies: 4Last Post: 29th Dec 2008, 15:54
