Is there any file or way i can use to check if my dvdplayer + tv can support a PAL DVD
What is DVD tells you the standards for PAL. Just create a simple clip using virtualdub and PAL resolution and framerate, encode and author as PAL. The only difference between PAL and NTSC is esolution and framerate.
Read my blog here.
Actually, the manual usully tells you if it plays NTSC or PAL or Both.
If you live in PAL-Land maybe....but this is a whole different ballgame in North America...Originally Posted by ultramarine
Video Playback, File Compatability
By TomFriedmann in forum Newbie / General discussionsReplies: 0Last Post: 14th Dec 2011, 09:14 -
Is there a small test video one can use to test Rec 601 / 709 conversion?
By Asterra in forum Video ConversionReplies: 5Last Post: 19th Jun 2011, 09:28 -
Any CD/DVD/USB test compilation available for checking player capabilities?
By roberta in forum Newbie / General discussionsReplies: 1Last Post: 18th Apr 2011, 15:48 -
How to capture NTSC video from PAL VCR player
By Cyberrock in forum Capturing and VCRReplies: 0Last Post: 28th Sep 2010, 04:36 -
How 2 test a PAL DVD in a NTSC environment?
By Charmed in forum Video ConversionReplies: 6Last Post: 2nd Jul 2007, 21:32
