i dont think i am using the right settings for vcd it isnt turning out right and there is no sound can anyone help.iam using dvd decrypter to rip the dvd
thanx
first i would recommend smart ripper -it decrypts and de macros...and you get smaller vob files. since you cna select which audio stream you want and ditch a load of other stuff- foreign dialogue and subtitles etc..
which flaskmpeg version you use? the one that does multi vob streams? or the 060 that does single mpeg2/vob ...
actually although i am a flask fan its not much good at vcd/svcd the picture aspect on the tepmplate provided is all wrong ...anyway ive been using DVDx1_6 for ages now amd the best thing is that you don't have to copy/desccs the bloody vobs to yer hd..think of all that space not taken up5gb of dvd data..its direct from dvd to vcd/svcd/svo all in one job...oh and you can set up 650mb limits so it splits the files into cd cuttables..and you can chapter the lot avi/vcd/svcd - not bad eh? -
iam using flask 0594 ive tried dvdx 1.6 but i am getting auth dll err its says drive may not b locked. the plug in settings dont seem 2 be working either
