I seem to have had maybe a 'french' <language> VOB player. Ive seemed to have lost it. if this catches your eye, have any idea what Im talking about?
its not ffmpegx someting else
it seems to have migrated elsewhere now that ive migrated to my MacPro.
its icon was green
Im sure ***ThaT*** narrows it down![]()
thanks
MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card -
Well for completeness sake, the program I was looking for, being ***green*** in icon color was Yade X
and its in french
I found it on a back up drive
is there any other program that allows you to open VOB and things and use a slider to scann the fiel
cheersMPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card -
Hi, rotuts
Your question: "is there any other program that allows you to open VOB and things and use a slider to scann the fiel "
is not very clear to say the least.
With SimpleMovieX you can open VOB files and perform some editing, export to other formats (with audio!). Files over 4GB are correctly supported.
http://www.aeroquartet.com/SimpleMovieX/
I hope this helps. (Note that I'm the developer of this app).
Regards, BJ -
Well Thanks BJ!
sory there were typing issues
what I meant is that if you go to Yade X, you and open a VOB or DVD movie elements and accually look at the various pieces and then move the slider on the bottom of the window and move a long.
Ill look at what you suggested and let you know.
Im of course looking to find a Yade X thats eventually all IntelMac.
cheers!MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
"Could not find any VOB unit in VOB file(s)" - Using Ifoedit
By devilcoelhodog in forum Authoring (DVD)Replies: 1Last Post: 1st Feb 2010, 23:01 -
Burning VOBs - error "Couldn't find any VOB unit"
By kshavo in forum Authoring (DVD)Replies: 7Last Post: 17th Feb 2009, 14:23 -
Attempting to demux VOB gives pop-up "file error" window eight ti
By taa in forum ffmpegX general discussionReplies: 6Last Post: 31st Aug 2008, 03:02
