I've tried to convert rm/rmvb files to avi in super, the converted file size is alright, but the quality is terrible compare to original. What settings or format or program should i use to convert so that the video quality is preserved?
Are you changing resolution ?
What codec are you encoding to ?
What bitrate are you using for video ?
What bitrate are you using for audio ?
What is more important - quality or size ?
If quality is the most important thing to you, ditch SUPER, and use avisynth to filter and resize before frameserving to virtualdub for econding. Frankly, I have never seen a real video file that wasn't already pretty flawed. SUPER doesn't do much i the way of clean up, and if you are resizing or using too low a bitrate, then all the horrible flaws inherent in real encoding will be made worse.Read my blog here.
Yeah, quality is most important. I don't want to resize. I want it so that so if i open rm/rmvb file in realplayer and the converted one in media player, thay would look exactly the same, quality and size wise. Right now, i'm using divx+mp3. I heard xvid and h264 are better, but not sure how to go about with h264.Originally Posted by guns1inger
The chases of you converting it to another format at the same resolution and quality and filesize are probably not great. Every conversion carries the risk of some degradation when using lossy compression, as every encode throws away data, even when you use the same bitrates and parameters.
SUPER has the option for h.264 and also losslessly compressed via Huffyuv.
Ignoring size for the moment, try outputting to Huffyuv to see what the quality is. As Huffyuv is losslessly compressed, saving at the same resolution as the original should give you an indentical image. From there you can load it into virtualdub to save it using another codec over which you have more control.Read my blog here.
RMVB conversion end up without audio
By alc112 in forum Video ConversionReplies: 22Last Post: 14th Jan 2010, 01:34 -
RMVB Convert to Mpeg2 quality
By anfield7 in forum Video ConversionReplies: 1Last Post: 10th Dec 2008, 23:58 -
rmvb format to mpeg conversion
By sumeshkri in forum Video ConversionReplies: 7Last Post: 2nd Oct 2008, 04:55 -
VirtualDubMod RMVB conversion problem
By pchan in forum Video ConversionReplies: 7Last Post: 22nd Nov 2007, 19:39 -
TMPGEnc problems with RMVB -> Mpeg2 conversion
By rebel316 in forum Video ConversionReplies: 2Last Post: 7th Aug 2007, 05:33
