Hi, I have a mate who has crashed his Toshiba Notebook and his local Tech has replaced the hard drive which was apparently damaged. I have data recovery software on my PC and I need to know if I can attach the HDD to my PC.? If so, which is the way to go? USB or what?
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
There are adapters that allow you too add the laptop drive to your main pc , the better option as most recovery tools will have no problems ... usb can be a problem , some tools dont work well with this option .
Take a spin around ebay should turn up the required adapter for a few bucks .
Computers & IT > Components and Upgrades > Cables, Connectors > Adapters, Converters
Look for (2.5" to 3.5" IDE adapter)
But this depend's on the type of "damage" .
If the drive can be seen in the bios , then there is a good chance of recovering files ... search for drive rescue , it's very good at recovery where others fail , not limited and free .
Basic recovery of work files , favs , outlook files can be done using puppy - mini linux distro .
Another option would be to mirror the content to another drive ... go to the manufacturer's website of the drive that buggered up ... grab there drive copy tool ... setup laptop drive as master , and another hd as slave ... it should contain no information , and be of the same format as the laptop hd ... need's to be same size or bigger .
The tool may complain if secondary drive is not from the manufacturer of the drive copy tool ... ignore it and proceed till job done ... worked when pro tools failed to transfer data .
If the drive cannot be seen in bios , then recovery could be expensive , depending on your needs .
This task is done by using another hd of the same type and specs in knowing working order , and swapping the platters between units for the recovery process to proceed ... -
First thing to determine is whether the drive spin up and stay on at all or not. If it is not then no software or other connection will work.
Note : I am not the other clock. -
Thanks Guys, all the info I need. I should have realized that there would be an adapter for it.
HDD Data Recovery - from Pioneer DVR-530H-S failed hard drive
By fortisMilvus in forum DVD & Blu-ray RecordersReplies: 17Last Post: 15th Feb 2025, 03:20 -
Digital glitch on Toshiba RD-XS35 HDD
By moxiecat in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Sep 2009, 01:11 -
Replacing HDD on Toshiba RD-XS52 DVD Recorder?
By DVWannaB in forum DVD & Blu-ray RecordersReplies: 17Last Post: 9th Feb 2009, 15:59 -
LiteOn HD A740GX HDD recovery
By Reiver in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th Mar 2008, 14:17 -
Swapping a Toshiba HDD
By next in forum DVD & Blu-ray RecordersReplies: 4Last Post: 24th Jul 2007, 07:49
