  1. Human j1d10t's Avatar
    Feb 2003
    California, USA
    Let me start out by explaining what I am doing.
    I am trying to convert the original theatrical versions of Star Wars to 16x9 widescreen. I did ROTJ and am trying to convert ANH using the same steps I used for ROTJ. I ripped the DVD using DVDDecrypter, used VOB2MPG to convert the VOBs to MPEG files, then used VirtualDubMPG to crop/resize the video and frame-serve to TMPGEnc to re-encode. I then used ChapterXtractor to extract the chapter points, and DVDSubEdit to open the VOB files and get the subtitles, saving them as .sup file - I want to keep the standard English and Forced English. I am now trying to get DVDAuthorGUI to author the DVD with the AC3 audio, chapters and 2 subtitle streams, then use VOBBlanker to replace the 16x9 version of the film with the 4x3, so I get to keep the menus from the original DVDs. I had no problems with ROTJ, and am pretty sure I'm following the exact same steps with ANH. The problem I'm having is when I load everything into DVDAuthorGUI and try to author the DVD it runs for a few minutes and then pulls up a message saying it could not complete the process and shows me the log:
    DVDAuthorGUI 1.009 beta release - 9/12/2006
    ***please wait while the titles are multiplexed.
    *multiplexing title: 1.....
    INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
    INFO: [???] File C:\STAR_WARS\ANH.M2V looks like an MPEG Video stream.
    INFO: [???] File C:\STAR_WARS\ANH.AC3 looks like an AC3 Audio stream.
    INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
    INFO: [???] Found 1 audio streams and 1 video streams
    INFO: [???] Selecting dvdauthor DVD output profile
    INFO: [???] Multiplexing video program stream!
    INFO: [???] Scanning for header info: Video stream e0 (C:\STAR_WARS\ANH.M2V)
    INFO: [???] VIDEO STREAM: e0
    INFO: [???] Frame width : 720
    INFO: [???] Frame height : 480
    INFO: [???] Aspect ratio : 16:9 display
    INFO: [???] Picture rate : 29.970 frames/sec
    INFO: [???] Bit rate : 7900000 bits/sec
    INFO: [???] Vbv buffer size : 229376 bytes
    INFO: [???] CSPF : 0
    INFO: [???] Scanning for header info: AC3 Audio stream 00 (C:\STAR_WARS\ANH.AC3)
    INFO: [???] AC3 frame size = 768
    INFO: [???] AC3 AUDIO STREAM:
    INFO: [???] Bit rate : 24576 bytes/sec (192 kbit/sec)
    INFO: [???] Frequency : 48000 Hz
    INFO: [???] SYSTEMS/PROGRAM stream:
    INFO: [???] rough-guess multiplexed stream data rate : 8263800
    INFO: [???] target data-rate specified : 10080000
    INFO: [???] Setting specified specified data rate: 10080000
    INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
    INFO: [???] New sequence commences...
    INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
    INFO: [???] Audio bd: buf= 16384 frame=000000 sector=00000000
    INFO: [???] STREAM bd completed @ frame 227120.
    INFO: [???] Scanned to end AU 174275
    INFO: [???] STREAM e0 completed @ frame 174275.
    INFO: [???] Multiplex completion at SCR=654115547.
    INFO: [???] Video e0: buf= 548 frame=174275 sector=02093349
    INFO: [???] Audio bd: buf= 14080 frame=227120 sector=00086523
    INFO: [???] VIDEO_STATISTICS: e0
    INFO: [???] Video Stream length: 4224074758 bytes
    INFO: [???] Sequence headers: 14885
    INFO: [???] Sequence ends : 1
    INFO: [???] No. Pictures : 174275
    INFO: [???] No. Groups : 14885
    INFO: [???] No. I Frames : 14885 avg. size 62588 bytes
    INFO: [???] No. P Frames : 44892 avg. size 33447 bytes
    INFO: [???] No. B Frames : 114499 avg. size 15641 bytes
    INFO: [???] Average bit-rate : 4648800 bits/sec
    INFO: [???] Peak bit-rate : 16507200 bits/sec
    INFO: [???] BUFFERING min 15 Buf max 191109
    INFO: [???] AUDIO_STATISTICS: bd
    INFO: [???] Audio stream length 174428928 bytes.
    INFO: [???] Frames : 2748657554
    INFO: [???] BUFFERING min 67 Buf max 10435
    INFO: [???] MUX STATUS: no under-runs detected.
    *preprocessing sup for title: 1 sub 1...
    1 file(s) copied.
    00:02:37.39XXX IndexError 0x20dd98.
    Writing image files and spumux.tmp.
    The system cannot find the file specified.
    *processing subtitles for title: 1 sub 1...
    DVDAuthor:pumux, version 0.6.12-alpha-2907.
    Build options: gnugetopt iconv freetype
    INFO: Locale=C
    INFO: Converting filenames to US-ASCII
    INFO: Detected subtitle file format: subviewer 2.0
    INFO: Opened iconv descriptor. *UTF-8* *ISO-8859-1*
    INFO: Read 0 subtitles
    INFO: Unicode font: 1185 glyphs.
    ERR: Couldn't load file C:\STAR_WARS\VTS_03_1 - 0x20 - Subtitle - English - Normal Closed Captions - [SP 01~ N] - DELAY 156890ms.SUB.
    Process aborted due to above error
    There was an unknown error. Please review the log for more information.
    I have tried reinstalling DVDAuthorGUI, I've tried using both versions 1.008 and 1.009 and get the same error. And what is weird is that DVDAuthorGUI says it can't load a subtitle file named "VTS_03_1 - 0x20 - Subtitle - English - Normal Closed Captions - [SP 01~ N] - DELAY 156890ms.SUB" which is not one of the subtitle files I tell it I want to use - it's not even one of the files I get from DVDSubEdit....
    "Don't try to be a great man. Just be a man, and let history make its own judgment."
    Zefram Cochrane
    2073
  2. Free Flying Soul liquid217's Avatar
    Feb 2002
    Please email me your project file (*.dva), and I will look over it.
    liquid_217@hotmail.com
  3. Human j1d10t's Avatar
    Feb 2003
    California, USA
    Cool! I'll send it as soon as I get home this evening.
    Zefram Cochrane
    2073
