In case this gets missed, my question was previously asked in a different thread:
https://forum.videohelp.com/viewtopic.php?p=1585435#1585435
There is only one NTSC format and one PAL format for DVD - basically defined by resolution and framerates. The different varients are governed by the playback device, not the disc. Therefore, there is no conversion to SECAM, it is just a PAL resolution/format authored disc, played back in a SECAM compliant player.
Read my blog here.
And it's credentials are . . . ?
SECAM is a broadcast standard. It does not apply to DVD. The DVD hardware takes care of it when it output to the TV.
/edit
It's credentials are very shaky. It's main page lists the k-lite codec pack as an "additional requirement" to the main software.
edit/Read my blog here.
Uh, this is not a recommendation on my part, just an example of a software listing SECAM as possible output (for those who actually look for this specific option...). Meant as encouragement to do more digging. that's all. Never used it, I admit.
this link explains the issue, also addressing a "SECAM-DVD" question
http://www.videointerchange.com/pal_secam_conversions.htm#SECAM -
There is no PAL / SECAM / NTSC on digital world. Framerates and framesizes are what makes the difference.
PAL / SECAM = Interlace 25 frames per second, 720 x 576 framesize
NTSC = Interlace 29.97 frames per second, 720 x 480
Converting 480 vertical lines to 576, is the easy part. Converting those 29.97 fps to 25 fps is complicated. Canopus procoder is the best solution for thisLa Linea by Osvaldo Cavandoli
NTSC in an area where Secam is used?
By B-Twien Bytes in forum Newbie / General discussionsReplies: 0Last Post: 2nd Jan 2009, 07:14 -
Help! - ntsc and secam versions of chapter authored pal dvds
By devdev in forum Video ConversionReplies: 3Last Post: 25th Aug 2008, 21:05 -
How can one convert WMV to SECAM?
By fledermaus in forum Video ConversionReplies: 1Last Post: 7th May 2008, 20:05 -
recording secam ?
By bugsbunny14 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 31st Dec 2007, 07:15 -
Can Secam Varieties Be Played Interchangeably?
By moviebuff2 in forum Newbie / General discussionsReplies: 4Last Post: 10th Jul 2007, 17:04
