So I used VirtualDub 1.6.16 to crop out a little bit at the beginning and at the end of a 98 MB home video in .avi format. When I save the resulting video it is 1.2 GB.
Here's precisely what I did: I selected the portions I wanted to delete using the Home and End keys and deleted them. I then saved the result with the "Save as .AVI" option.
I know squat about video editing... or anything video related actualy. I am guessing that the original file is compressed and the resulting one isn't but how to fix this, not a clue.
So how do I end up with a reasonable sized file? Help greatly apreciated.
Use video->direct stream copy and audio->direct stream copy and you wont reencode the video to uncompressed format.
You forgot to specify a compression codec, so VD gave you the default 'Uncompressed RGB', which will give you a huge file.
Just set the compression from one of the codecs in the list. I would use the same codec as the original.
But if you are just doing simple editing, save it out as a 'Direct stream copy' and it should be the same as the original, minus the cuts. This is also very fast as no re-encoding is involved. But you would need to make your cuts on a keyframe, or you would have to re-encode at least the parts where you made your cuts. Keyframes are automatically jumped to by the little key symbols.
The problem is, some codecs like Xvid, Divx only have a keyframe every 300 frames by default. So that's as fine as a cut that you can make without re-encoding. 300 frames at 29.97fps and you see the problem.The DV codec has every frame as a keyframe. Very nice to edit.
Keepvid - how can you chose where the downloaded file is saved?
By jacknscoob in forum Newbie / General discussionsReplies: 1Last Post: 18th Feb 2012, 23:09 -
Capturing with VirtualDub - File size 400GB and only 2 hours from old rec
By Diegovh1 in forum Capturing and VCRReplies: 15Last Post: 28th Jan 2012, 06:40 -
VirtualDub + Xvid: problem with file size in 2 pass encoding.
By marcinkk in forum Video ConversionReplies: 3Last Post: 8th Dec 2011, 15:47 -
VirtualDub -- XviD file size problem
By higgins327 in forum Video ConversionReplies: 8Last Post: 29th Mar 2011, 16:05 -
Please Help! Can't Get VirtualDub-MPEG2 file size down!
By dano187 in forum DVD RippingReplies: 2Last Post: 26th Jun 2007, 19:15
