i recorded a couple of movies scheduled one after the other. i came home and prepared to view the movies. i checked the folder and found one large mpg file ( i capture to full D1). Curious i tried to play the file but it would not play in media player or cyberlink. i tried to load the file into tmpgenc dvd author and i got a pop up saying i am denied access. so now i restart the computer and guess what ? the file disappears. i mean gone completely. i am upset because the movies don't come around very often. anyone have this happen to them. What gives ?
Sounds like the files were still in use. I expect your recording software experienced a malfunction and did not write the file, what you were seeing was most likely the temp recording file...hence the reason you were denied access.
It could be a software glitch or depending your HD format (FAT32 or NTFS), you may have hit a file size limit.Google is your Friend
Captured video but what to do since file is huge.
By I26 in forum Newbie / General discussionsReplies: 3Last Post: 30th Dec 2010, 20:19 -
Captured AVI file too large
By drgt in forum Newbie / General discussionsReplies: 38Last Post: 29th Sep 2010, 08:22 -
how do I tell what date a dv file is from captured with windv?
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 16th Dec 2009, 08:04 -
Shortening a Captured File
By solarblast in forum EditingReplies: 8Last Post: 21st Jul 2007, 13:19 -
Captured File Size Question
By pbmc59 in forum Capturing and VCRReplies: 10Last Post: 6th May 2007, 21:41
