Using the Join tool in ffmpegX results in the audio portion of the second avi joined to be out of sync.
These files were made using the ffmpegX AVI mencoder setting, video size=640 x 352 pixels; audio as mp3 128kbps 48000 hz stereo and this is the same on both clips. I thought I used the XviD Codec but info in Quicktime says they are both DivX. The only difference info in QT shows is that the frame rate in the first is 23.97 & in the 2nd is 23.99.
I do not see any variables to the join tool, how do I correct this?
Why is the first clips audio in sync, but the second clip is out of syn in the resultant joined file?
The second clip source used to make the join is in sync prior to being joined.
ALSO
What is an advisable way to trim an AVI?
ALSO
Every attempt to convert a trimmed QT .mov to an AVI with any CODEC in ffmpegX fails.
One info says:
Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
mencoder(1362) malloc: *** vm_allocate(size=4294578176) failed (error code=3)
mencoder(1362) malloc: *** error: can't allocate region
mencoder(1362) malloc: *** set a breakpoint in szone_error to debug
Why can I not convert these?
Results 1 to 1 of 1
joining mp4 files but audio out of sync
By Liselotte in forum Newbie / General discussionsReplies: 2Last Post: 1st Aug 2011, 22:18 -
audio sync problem joining two avi files
By kthan in forum EditingReplies: 11Last Post: 2nd Apr 2011, 13:52 -
Audio out of sync (with over 0.5sec) when joining multiple avi files
By andy_blah in forum Video ConversionReplies: 28Last Post: 10th Aug 2008, 15:55 -
Audio Sync Problem Joining 2 AVI's Together from a 2 DVD Set
By boofer in forum EditingReplies: 6Last Post: 22nd Jul 2007, 02:29 -
Joining 2 avi files, error with audio streams, need help
By leinan in forum Newbie / General discussionsReplies: 5Last Post: 8th Jul 2007, 07:12
