Recently I made a dts 5.1 cd which plays very well on my dvd player. So I had this question.
Can I make a dts 5.1 audio dvd?
I burnt the dts cd with nero by selecting normal red book audio cd format , but what should I do to burn a dvd ? does nero have any way to do it or should I use any other software?
Audio DVD Creator
/Mats -
Not the same way as a dts 5.1 cd red book audio format.
You can instead make a dvd-video with for example a still image background and dts sound. -
DTS audio Cds are higher quality than most DTS dvds
Doesn't DVD Video Specification supports 24 bit / 96 kHz audio.
supports yes 96 kHz audio - but production disk dont use this spec for the most part ..
dts cds are 20bit out of the box - but rare
converting any dvd ac3 or normal cds to any of these formats is of course a waste of time and effort unless you have the master tapes ..
plus you will need a couple grand of software"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I have audio dvd creator and I made a stereo dvd with that , plays very well with DPLII Ex but if I try to use 5.1 mode the programme crashes.
I have the encoding softwares but I do not know which dvd authoring programme accepts dts audio stream with blank video
I can make this dvd in DD 5.1 but I feel the performance of dts cd was better so I want to stick to dts ( my personal openion)
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 17:25 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 22:24 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 13:10 -
Reauther dvd with pcm & dts to ac3 & dts
By djblade in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2010, 09:40 -
DTS encoded disk, output to DTS receiver using an HTPC
By ChipMcC1 in forum Media Center PC / MediaCentersReplies: 6Last Post: 18th Nov 2007, 08:06
