Hi everyone.
I'm currently working on PAL footage captured from VHS through composite connection. I'm using Canopus ADVC 110 and the new digital format is PAL DV.
It seems that after capturing(without applying any filters/any editing), the people look sort of like paintings. I was wondering if anyone knows what's causing this?
I would prefer avoiding filtering because this video is already at high quality. But I was wondering if the problem lies with the playback or something of the sort that can be fixed.
I've attached a sample frame to make things easier to understand.
With Regards,
Guy.
Results 1 to 11 of 11
I doubt my VCR has noise filtering. It's quite a basic one
I tried playbacking the movie on TV without capturing and it seems that the source also looks somewhat 'smudged' and 'painted'. However, after capturing it looks worse. Or could that be because my PC-LCD screen is much sharper and clear than my old TV-CRT screen so that what's making the difference?
My father told me that this is normal because when analog footage is duplicated several times - You get the side effect of smudged colors, which tend to make people look like they are painted. I wonder if this is true and my capture only makes it more noticeable? -
Do a capture from your DVD player to your capture card, then you'll know if the problem is your card or the original VHS tape.
He's a liar and a murderer, and I say that with all due respect. -
Thank you
All other sources seem to work ok.
I tried changing the composite cable and now the results are somewhat better - more or less like the original VHS tape.
The characters still look like paintings, but the colors are more alive. I am wondering though, is there anything to do regarding the 'people looking like paintings' thing? or there's no way to make it less visible since this is the source I have? -
Somewhere between the VHS tape and the image you posted there is some very heavy noise filtering going on. VHS is not that noise-free.
Have you tried looking at your DV AVI file with something other than WMP? The video frame in your sample is about 816x628 so it has been resized by WMP and there's no telling what else might have done. I recommend you view your DV AVI file with VirtualDub. It will show you something much closer to what's in the file. -
Thank you both.
Watching the file in Vdub seems more or less the same. for some reason this tape is really pretty much noise free. This is without applying any filtering whatsoever. I think I'd just leave it as is, unless anyone has any other idea. I don't really want to add more noise - I prefer it this way.
As I said earlier - changing the cables helped a little, but I guess the source it to be blamed here :/. -
I’m not sure if my words here would matter but you know I have been looking for this kind of player. I’m in need of players that would show up videos of people or any event in as if painted form. I can very much work on my orders from friends and customers with this kind of player. Would you mind telling me where did you get your present player?
JohnWe represent portrait artists from all around the world and we specialize in turning any perfect photo into a painting portrait as a perfect anniversary gift. -
@Portrait - you could look at something like the MSU Cartoonizer plugin for virtualdub, which would give you more control and a predictable outcome. I suspect that the tape is as much a factor in the OP's results as was the player - probably more-so.
You can find it here : http://www.compression.ru/video/cartoonizer/index_en.htmlRead my blog here.
PAL People with TV Tuners/Capture Cards - Uncompressed
By zerowalker in forum Newbie / General discussionsReplies: 75Last Post: 29th Feb 2012, 00:38 -
40 second animation
By Ken-B in forum Off topicReplies: 3Last Post: 24th Nov 2011, 09:23 -
Resizing Animation
By roflwaffle in forum Newbie / General discussionsReplies: 4Last Post: 19th Jul 2010, 12:04 -
wow heres one for you learned people - capture from within
By ancient in forum Capturing and VCRReplies: 4Last Post: 13th Jul 2007, 20:09
