Ive bumped into some .mkv files. MPlayer OSX tries to play them but won't
is this only for windows?
any mac converters out there? Ive gone to the mkv site but it seems only windowsy
cheers
MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card -
Quicktime (with Matroska and Perian components) and VLC are able to read most mkv files, providing they do not include any RealMedia track (RV40...). VLC is better, though, because you can easily choose your language in case of multiple audio/subtitle tracks.Originally Posted by rotuts
If the file contains RealMedia tracks (which is most probably the case) you'll have to use mplayerOSX with the Helix Real libraries. I don't know if this works for Intel based Macs.
If you want to do some conversion, use MKVExtract, then process the tracks with ffmpegX.
EDIT : the link is not working anymore. Use this Rapid Share link instead.Jean-Philippe Schuck
Un générique, un autre jour, le blog sur les génériques de dessins animés
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
mac program that converts mkv?
By furida in forum MacReplies: 4Last Post: 17th Aug 2009, 16:59 -
is there a good mkv extractor for mac out there?
By malakov08 in forum MacReplies: 5Last Post: 27th Apr 2009, 14:02 -
multiplex mkv on mac
By kirti in forum ffmpegX general discussionReplies: 2Last Post: 7th Jan 2009, 07:57 -
Convert MKV's audio on Mac
By frosse in forum MacReplies: 9Last Post: 28th Feb 2008, 18:09
