Hi folks,
Just a silly question, I've never used TSCV, I used to author VCDs with Phillips VCD2.0 Toolkit, which I liked very much as it supports chapters as well as Menu-sound,moving menus etc. The only thing I hated was, that it supported only strict VCD2.0 compliant Mpeg-Files. Now I heared that TSCV also soppurts Chapters and moving menus, so I'd like to know if it also supports files VCD-Mpeg-Streams with a lower bitrate and XVCDs in general. Thanx for your answers,
NickmanXXX
TSCV is a GUI of VCDImager and yes, you can make non-standard discs with VCDImager.
Regards.
Michael Tam
w: Morsels of Evidence
compatible files
By woody12 in forum Media Center PC / MediaCentersReplies: 1Last Post: 17th Jan 2011, 11:43 -
What does HDTV compatible mean?
By optimus in forum DVB / IPTVReplies: 27Last Post: 6th Feb 2009, 03:19 -
TSCV on Vista
By mrcoolekin in forum Authoring (VCD/SVCD)Replies: 4Last Post: 11th Feb 2008, 23:04 -
Vista compatible?
By Slowburn in forum DVD RippingReplies: 2Last Post: 14th Jun 2007, 10:55 -
Want More Memory - Is This Compatible?
By daamon in forum ComputerReplies: 5Last Post: 5th May 2007, 09:19
