    Jul 2004
    I have a two hour mpg which is basically 5 22 minute shows that I want to turn into 5 chapters. Any easy tool I can use? I have Nero but cannot fugure out how to do it.
    Apr 2004
    Miskatonic U
    If you want them as chapters, don't plit the file. Just read the help file for your software to work out how to put in chapter markers.
    Read my blog here.
    Jan 2004
    Middle of England
    I would go along with the TDA suggestion.
    Oscar.
    Jan 2002
    I usually use VideoREdo plus and split them. I then add them to TDA . I seem to get more of an exact split with VideoRedo than I do with TDA. If you add each file that you split TDA will make them chapters.
