Hi !
I'm currently using ConvertXtoDVD to author my DVDs, currently I'm processing
39 fps, what would I need to change in my hardware to improve that ?
Processor ? (currently AMD Athlon XP 2800+)
Video Card ? (Radeon 9800 Pro 128)
Both ? And if it's both, please tell me in what proportion one is more important than the other
(if you know, of course).
Anyway, give me a general idea...
Thank in advance.
Video card has nothing to do with it. CPU will make some difference, but not as much as you would hope. On the bright side, if you were using a good quality encoder, doing mutli-pass encoding, perhaps filtering the video to clean it up, then authoring in a proper authoring tool, the whole process would take much, much longer.
ConvertXtoDVD is about as quick as it gets. The amount of money would would have to spend to speed it up would not be worth the difference it would make.
If you have two hard drives, try saving the output from ConvertXtoDVD to a different drive to the one the movie is on. That is probably worth a frame or two per second.Read my blog here.
I'd say 39 fps is pretty impressive...
/Mats -
I don't know about COnvertXtoDVD but TMPGEnc and CCE on a Athlon 64 X2 3800+ encode about twice as fast as an XP 2800+. That would require more than just a CPU swap though. A low end Core 2 Duo runs about the same speed (and cost) as the X2 3800+.
improve old VHS
By mathmax in forum RestorationReplies: 108Last Post: 2nd Nov 2011, 12:43 -
How do I speed up my video to 10X speed?
By mileena in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2010, 13:24 -
What can I do to improve my quality?
By Captain Satellite in forum RestorationReplies: 12Last Post: 27th May 2009, 11:06 -
dvd authoring speed question
By slaak in forum Authoring (DVD)Replies: 0Last Post: 25th Jan 2009, 13:14 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 02:41
