When recording a programme from certain TV stations they put their great big ident logo where it becomes a big distraction ( ITV 4 UK uses) is there a way to remove these annoying logos when I save to disk via a encoder? and if so could you point me in the right direction![]()
Cheers
Oscar.
VirtualDub - Delogo.
Search on DeLogo should bring up several threads on this subject."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
Instead of a logo, now you'll have a big blob.
That depends on the level of transparency of the logo and how clean the source video is. Some logos can be removed without leaving any noticable artifacts. But if the logo (or parts of it) is opaque or is in motion then DeLogo blending will leave noticable "blobbing".Originally Posted by lordsmurf"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
Delogo can indeed remove most alpha-blended logos quite well, and does not leave a blurry blob when used correctly.
Thanks for the info guys I came across this old thread that most of you guys posted on,it may be of interest to others.
https://forum.videohelp.com/viewtopic.php?p=1376335
Oscar. -
For really stubborn logos, you can run more than 1 instance of delogo. On 1 really tough project, I used 3 instances of Delogo. The first one was set for only alpha-blended removal of 1 of the logo parts. The second was with both repair and deblend removal, and the 3rd instance was repair only. This was needed as this particular logo had both an alpha-blended logo, and a solid logo.
I have found that on some unstable logos, where the logo shifts left and right a hair because of instability of the station, a comb filter can really help. I use the dot-crawl filter for those before I make the mask.
EDIUS Laptop Edit Station
By atomicock in forum EditingReplies: 3Last Post: 29th Oct 2010, 13:36 -
Timer record a TV station stream?
By RedPenguin in forum Video Streaming DownloadingReplies: 3Last Post: 20th Apr 2009, 01:37 -
Sub Station Alpha will not install
By slobjones in forum SubtitleReplies: 2Last Post: 14th Apr 2009, 16:55 -
Set up a TV Station!
By SatStorm in forum Video Streaming DownloadingReplies: 2Last Post: 1st Aug 2008, 17:18 -
2 Logos on a TV Station
By gll99 in forum Newbie / General discussionsReplies: 10Last Post: 23rd May 2007, 18:18
