when i use virtualdub to encode my vid with subs it works fine except that the japanese text does not appear correctly. it looks like this : $%^#$&^%$&^
obviously this is an issue with encoding, but i dont know what to do. when i open my subfile in notepad the japanese is displayed perfectly.
Your subs are Unicode, ShiftJIS, or some such. I'm not sure if the VirtualDub sub filters can handle that.
you could try setting your regional settings for non-unicodes programs to japanese in control panel (you will have to reboot, and all backslashes in explorer will look like yen symbols).
control panel -> regional and language options -> advanced tab -> Language for non-unicode programs (drop down box) select Japanese. -> click OK -> Reboot.
Be warned, installing some programs when running japanese codepage can result in those programs using japanese text. Nero is one example.Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
Subtitle not showing up when Hardsub mencoder
By baoky in forum SubtitleReplies: 0Last Post: 23rd Jun 2011, 10:58 -
subtitle workshop cant read japanese subtitles
By aruwin in forum SubtitleReplies: 4Last Post: 2nd Feb 2011, 09:55 -
avi is not showing in subtitle workshop
By simonrule in forum SubtitleReplies: 3Last Post: 11th Dec 2009, 15:51 -
japanese subtitle issue
By kay in forum SubtitleReplies: 7Last Post: 15th Jul 2009, 19:45 -
Subtitle not showing w/Xvid in Virtualdub
By luketheduke in forum Video ConversionReplies: 10Last Post: 4th May 2007, 14:58
