Hi,
I have a video in MPEG4 format and cannot see it with quick time, nero show and vlc. any help?thanks/Fabio
thanks with the last version of vlc it works.
the video files are 2 how can I link them to do only one dvd (virtualdub doesn't work)? -
Are you wanting to convert them to MPEG-2 for a DVD that will play on a settop player? If so, don't join them. Let your authoring program set them up to play one after the other. You avoid a lot of problems with sync loss that way.
If you are just burning them as a DVD data disc, then VD should be able to join them if you have the proper codecs installed. Being that only VLC plays them, I suspect you don't have the right codecs installed.
And there are a lot of MPEG-4 formats. It depends on which one you have. Gspot 2.60 or Mediainfo should tell you which codec you need.
Convert MPEG4 Video to VOB?
By jfreytag in forum Authoring (DVD)Replies: 6Last Post: 30th Oct 2010, 21:55 -
Video studio 9 and mpeg4
By jimbon in forum EditingReplies: 2Last Post: 3rd Dec 2008, 09:30 -
Mpeg4 to make youtube video?
By chronic777 in forum Video Streaming DownloadingReplies: 8Last Post: 18th Jul 2008, 17:09 -
mpeg2 to mpeg4 video quality
By Starkian in forum Video ConversionReplies: 5Last Post: 29th Jun 2008, 09:36 -
MPEG4/Divx to DVD video help
By Cruton502 in forum Newbie / General discussionsReplies: 1Last Post: 4th Nov 2007, 05:00
