Hi,
Am I safe to assume that the Real media encoder in premiere pro, using the mainconcept codec, is not the same as using the mainconcept encoder?
Basically, my choices are to output to dv avi, then use tmpgenc to encode to burn on dvd, or use the real media encoder and choosing mainconcept , then burn to dvd.
tmpgence can be a bit tad slooooower, but from what I've seen, the quality of the real media encoder isn't the best. I have heard that mainconcept is really good, but that would be its own encoder, not through the real media encoder, correct?
Thanks!
winxp - 3.06 -
Originally Posted by bufalo
http://www.real.com/
The Adobe Mpeg Encoder (Mainconcept technology) is for MPeg1 and MPeg2 encoding and is built into Premeire Pro.
Originally Posted by bufalo -
OOPs! I meant to say "adobe media encoder", not "real media encoder" I'm going to be reading the manual (yet again) tonight. Then again, I also don't see adobe MPeg Encoder in the export menu either is this the same as "adobe media encoder"? and just use mainconcept.
But in the end, is the adobe media encoder, using mainconcept comparable to tmpgenc. I ran some quick tests and saw a difference, but it could just mean I have to tweak some stuff.
thanks for all your help, I hope to get out of the newbie stage at one point!winxp - 3.06 - -
http://www.mainconcept.com/adobemedia/adobe_media_faq.html
http://www.creativecow.net/articles/sareen_aanarav/premiere_pro_2/index.html
http://www.mainconcept.com/site/index.php?id=111
Rovi buys MainConcept
By lordsmurf in forum Latest Video NewsReplies: 5Last Post: 17th Feb 2014, 01:14 -
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 09:24 -
MainConcept products !? use it or not..
By Harviz in forum EditingReplies: 1Last Post: 1st Dec 2007, 20:14 -
TMPGEnc Xpress, MainConcept, H.264 and QuickTime Compatibility
By PuzZLeR in forum Video ConversionReplies: 6Last Post: 27th Oct 2007, 04:05 -
Mainconcept DV Codec Vs. The Rest
By SeeNoEVO in forum Video ConversionReplies: 25Last Post: 5th Jun 2007, 08:16
