Does anyone know how to use the internal Null Transform filter in Vdub for cropping? It doesn't allow the user to optimize or make setting changes?
Thanks!
Null (meaning Nothing) just allows you to crop an AVI. You could, for instance, crop 10 pixels from each side of a 640X480 making a 620X460 AVI. Hard to see how a filter that basically does nothing could be optimised...
Cropping can be attached to any filter. Select a filter than press the Cropping... button on the Filters dialog. Note that copping takes place before the filter is applied.
If you are doing no other filtering you can add the Null Transform filter and attach cropping to it.
MPC-HC Transform Filter deinterlace question, searched form
By gOdiSOnyOuRsIDe in forum Software PlayingReplies: 3Last Post: 5th Mar 2012, 23:58 -
failed pBuilder -> RenderStream ( NULL, NULL, pPin, NULL, pMux)
By newbie_noob in forum Newbie / General discussionsReplies: 0Last Post: 19th Feb 2010, 08:10 -
How do I make a filter for VDub
By blaze01 in forum Newbie / General discussionsReplies: 4Last Post: 4th Mar 2008, 16:16 -
Applying a filter without recompressing in VDub
By chrisr34000 in forum EditingReplies: 5Last Post: 25th Jan 2008, 17:42 -
Vdub Filter Chain
By christopheramos in forum Video ConversionReplies: 16Last Post: 3rd Sep 2007, 07:57
