I have an avi file which it's audio is in english but a second later you hear a russian audio.How can I seperate the 2 audio so I can hear the english audio only?
Hello from the island of Malta.
If it's been dubbed (i.e. Russian is overlaid on top of English) the answer is no. If it's on a separate channel, just turn that channel off.
How can I know if it's on a seperate channel or not?
Hello from the island of Malta. -
First, check if it's stereo or not. If it's 5.1 you can forget it.
If it's stereo, just try flipping the balance all left vs. all right. (Use the "mixer" to do that) -
Does it come out of one speaker, or both ?
If both :
Open it in virtualdubmod. Go Streams -> Stream List. If you have only one audio track, then you may as well delete the file.Read my blog here.
Only one file.I deleted it. Thanks for your help.
How to fix audio synch problem in AVI file
By vertical in forum Newbie / General discussionsReplies: 153Last Post: 20th Aug 2021, 07:45 -
Audio Sync Problem, Repairing and AVI File?
By JerryRecords in forum AudioReplies: 1Last Post: 5th Dec 2008, 00:38 -
Major problem loading audio from AVI file into Auto Gordian Knot v 2.45
By robo5050 in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2008, 07:12 -
Audio problem when converting a MPEG file to AVI
By Kareng in forum ffmpegX general discussionReplies: 9Last Post: 18th Jul 2008, 18:50 -
By Kareng in forum AudioReplies: 1Last Post: 2nd Jul 2008, 16:56
