need some suggestion to the proper way to deinterlace this movie.
Clip
please confirm that your suggestion works before suggesting it. I have tried a few without success. namely:
fielddeinterlace(blend=false)
restore24()
leakkerneldeint(order=1,threshold=8)
leakkernelbob(order=1)
repal()
I may have tried some others that I forget right now. please help!
				Results 1 to 11 of 11
	In AVISynth
 LeakKernelBob(Order=1)
 Decimate(cycle=2)
 wasn't too bad. Unfortunately the source is in pretty poor condition (partially blended fields) so the result has some ghosting.
 There is a filter called RePAL that can remove a lot of that ghosting but it assumes the source is a partially blended PAL->NTSC conversion. So it won't work properly with your source.
	ok, I will give this a try. thanks
 edit:
 gave pretty much the same result as my previous best. not good enough to keep as a copy.
 why do they have to make things so hard? damnit.
  need help unblending previously blended frames rather than dropping framesBy BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 22:15
  yadifmod+nnedi2 = blended frames?By lordsmurf in forum RestorationReplies: 10Last Post: 14th Jul 2010, 07:48
  IVTC of 'Castle' episode leaving blended frames (ghosting?)By txporter in forum Video ConversionReplies: 39Last Post: 2nd Apr 2010, 15:03
  Frame blended and duplicate framesBy loekverhees in forum Newbie / General discussionsReplies: 7Last Post: 2nd Jan 2010, 10:35
  Fields problemBy themaster1 in forum RestorationReplies: 4Last Post: 14th Oct 2008, 19:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
