Probably a dumb question, but I can't see why it wouldn't be possible.
I have a bunch of 320x240 clips that don't play correctly in my standalone (it needs 352x240). I just want to add 16px black borders to either side, but reencoding kinda defeats the purpose - to get similar file sizes as the originals, the reencoded files look like crap, not to mention the time it would take to reencode them all.
Thanks in advance.
JJ
Actually, I believe the answer is NO.
Regards.
Michael Tam
w: Morsels of Evidence -
I believe you're right! lol
I spent a couple hours trying to come up with some solution to this and found nothing...
I'm still thinking its possible though, but the software doesn't exist. -
You could burn it as an XSVCD with Nero 5.5 with compliant CD unchecked in the SVCD settings. It would make a low resolution SVCD with low bitrate as well, but play it correctly as if it were a VCD. Maybe even try making an XVCD, although I haven't tried departing from the VCD standard, only SVCD.
<font size=-1>[ This Message was edited by: tweakybird on 2001-07-24 15:06:22 ]</font> -
My player is really finicky about video dimensions - it will only play correctly at standard sizes, although it has no problem with nonstandard bitrates.
Add borders to MKV without reencoding?
By squadjot in forum Video ConversionReplies: 3Last Post: 16th Nov 2010, 13:53 -
How do I join avis of different dimensions together? Or add borders?
By thedarkness in forum Newbie / General discussionsReplies: 9Last Post: 24th Jul 2010, 18:19 -
any free tools to resize/clip mpg2 and add black borders?
By extent in forum EditingReplies: 4Last Post: 16th Dec 2009, 17:23 -
2.35 : 1 content for DVD compliant without encoding black borders?
By d4t in forum Video ConversionReplies: 4Last Post: 1st Jun 2009, 10:16 -
Easy way to add borders to h264 video?
By cbl016 in forum Newbie / General discussionsReplies: 2Last Post: 10th Oct 2008, 02:51
