hey guys im having a problem trying to install "Subtitle Creator" when i run the setup file, ti gives me an error saying : ".Net runtime library is not installed", what can i do? i downloaded the file from the link given in this website...its called "Setup_SubtitleCreator_V2_0_6.exe".
Plz help
you must install .net framework, http://www.microsoft.com/downloads/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15...displaylang=en
I split this off as a new thread.
/Mats -
VOBs usually don't show subtitles (player dependent). But the DVD (correctly authored) may do.
Could you recap what you've done? So far all facts is:
You've tried to install Subtitle Creator but that didn't work.
Solved the problem (which?) by using ReJig, but still, some VOB doesn't show any subs.
/Mats
Subtitle Creator - Unable to set Default Subtitle Colors & Default Prof
By blue2 in forum Authoring (DVD)Replies: 2Last Post: 15th Nov 2009, 22:47 -
Subtitle colours in subtitle creator
By Belfour in forum SubtitleReplies: 3Last Post: 22nd Oct 2009, 02:00 -
Subtitle Creator noob
By Kuda in forum SubtitleReplies: 1Last Post: 3rd Oct 2009, 02:23 -
WMV to DVD and problem installing Easy Media Creator 10
By jhayes in forum Video ConversionReplies: 3Last Post: 10th Mar 2008, 14:26 -
question about installing Subtitle Creator Wizard
By jimdagys in forum SubtitleReplies: 1Last Post: 18th Oct 2007, 09:46
