Hi:
When before I decided to install Nero Show (big mistake) and used dvd decrypter(and dvd fab express) the file exstensions used to go like this IFO, VOB, BUP. Now since installing Nero Show the file extension have changed to Backup File of the IFO, DVD Movie and DVD Movie Info. Which is very confusing to me.![]()
Is there some way I can reset both decrypter and dvd fab back to the old file extensions??? Do I need to uninstall them both and reinstall them???
Help!
All you need to do is to change the way Explorer shows these files. Open the folder, go to Tools - Folder Options, choose the View tab and deselect the "Hide extensions for known file types" option.
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. -
Originally Posted by träskmannen
Thanks for your reply. I did what you suggested; using Window's Explorer and I did notice the file exstension like you said. Is there some way to get the file extensions to show up under the "TYPE" of file(that's where the way it used to be before I screwed things up)? See new attachment.
Thanks again.
dvd%20decrypter%20file%20exstension%202.bmp -
You can also go to any folder, 'Tools>Folder Options>File Types' and change the filetypes for VOB, IFO, and BUP if they are shown. Change the association to DVD Decrypter or change what action is available when you right click the file.
Protron DVD player PD-007 in Progressive mode How do I reset.
By joe347 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 25th Nov 2013, 20:36 -
How to reset the DVD drive region code?
By coody in forum DVD & Blu-ray WritersReplies: 13Last Post: 17th Apr 2010, 03:42 -
Frogot Reset password to play Panasonic DVD LS83
By ikecanada in forum DVD & Blu-ray PlayersReplies: 5Last Post: 24th Mar 2009, 23:36 -
Win XP - How to reset the DVD/CD burner?
By coody in forum ComputerReplies: 1Last Post: 7th Feb 2009, 23:15 -
How can I reset my Sanyo DVD player?
By 89SDML in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Feb 2008, 11:08
