I've found that some DVD players default to subtitles on.
Eventually I found that I can use PGCedit to edit the IFO files and set a default "off" by inserting a "SetSTN=62" command whihc overrides this.
I suspect there is a way to do this within GfD by editing a button function, or perhaps the XML file. Can anyone confirm this?
(There are actions "Set subtitle =0/64/65/66", which look similar.)
Exactly... You can edit the XML and use a command like 'subtitle=62' or 's2=62' to force all subtitles to the 'off' state. The command has to be inserted in the titleset domain (either as < pre > command of the titleset menu or as < pre > command of the title itself). In the mainmenu it has no effect.
GUI for dvdauthor:
https://www.videohelp.com/~gfd/
GfD - Subtitle error
By michcio in forum Authoring (DVD)Replies: 14Last Post: 4th Jul 2009, 10:17 -
add a subtitle (.sup) to a mp4
By dmdevotee in forum SubtitleReplies: 6Last Post: 24th Jul 2008, 09:46 -
How can I add a subtitle into ts file in DVB subtitle format
By elmc in forum SubtitleReplies: 1Last Post: 20th Jul 2008, 15:37 -
default subtitle and audio commands for DVDAuthorGUI
By ecc in forum Authoring (DVD)Replies: 2Last Post: 21st Dec 2007, 21:06 -
GUI For DVDAuthor (GFD) won't let me add audio
By rail in forum Authoring (DVD)Replies: 9Last Post: 14th Jun 2007, 03:53
