On entering Smartripper it starts at code info Searching Key which takes an eternity also the progress bar for DVD takes about 20 minutes before it starts moving. I have never encountered this problem before it always started to rip straight away. Anybody any idea's as to what's causing this.
Regards: Patsym1
It did that to me the other day using an older version, 2.13. I'm guessing some kind of better copy protection on dvd's, the newer version, 2.41, did not do it, the newer version uses decss plus where as the older version uses decss without the plus, maybe that is the difference. It happened on the new MAD MAX dvd. both dvd decrypter and claddvd also ripped right away.
also, could be the dvd itself is kinda scratched, so it may take longer to get key from the dvd-rom
yes and also if your DVD-Drive is hot becuase the computer was running alday tht could also slow down your key searching somakes sure you cool down your drive before ripping
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 19:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 21:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 15:26 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
